2015 ram EcoDiesel dumping the oil out as fast as it can go in between motor and transmission
alphaRamecoshit
This 2015 purchased had clean service record and was very reliable never really had any issues until it dumped all the oil. Since it blew the oil out it will not hold the oil anymore we've searched high and low for where it could be is it a rear main seal any thoughts? Also in between transmission and motor there are two wires that come off of the bottom of the oil pan what do those go to any thoughts? any help??? please
DieselBot
1. Oil Leak and Potential Causes
If your engine "dumped all the oil" and now won’t hold oil, it suggests a major failure or seal breach. Here are some possible causes:
  • Rear Main Seal Failure:
    A blown rear main seal (between the engine and transmission) is a common culprit for large oil leaks. If oil is pooling between the engine and transmission, this could be the issue. Replacing the rear main seal is labor-intensive, as it requires removing the transmission.
  • Oil Pan Gasket or Cracked Oil Pan:
    If the oil pan gasket is damaged or the oil pan itself is cracked, it could cause a significant leak. Inspect the oil pan for damage or signs of oil seepage.
  • Turbocharger Oil Lines:
    The EcoDiesel has oil lines running to the turbocharger. If one of these lines or fittings failed, it could cause a massive oil leak. Check the turbo area for signs of oil.
  • PCV System or Crankcase Overpressure:
    Excessive crankcase pressure (e.g., from a clogged PCV system or blow-by due to engine wear) can force oil out of seals or gaskets. If the engine was overfilled with oil or has excessive blow-by, this could exacerbate the issue.
  • Oil Cooler or Filter Housing Leak:
    The EcoDiesel has an oil cooler and filter housing that can develop leaks. Inspect these components for signs of oil.
2. Wires Near the Oil Pan
The two wires you mentioned near the bottom of the oil pan are likely for one of the following:
  • Oil Temperature Sensor:
    The EcoDiesel has an oil temperature sensor that monitors oil temperature. If the wires are damaged or disconnected, it could cause issues with oil pressure readings or engine performance.
  • Oil Level Sensor:
    Some vehicles have an oil level sensor in the oil pan. If the wires are damaged or disconnected, it could affect oil level monitoring.
  • Ground Wires:
    These could also be ground wires for the engine or transmission. Loose or damaged ground wires can cause electrical issues.
Inspect the wires for damage or disconnection. If they’re part of a sensor, ensure the sensor is functioning properly, as a faulty sensor could lead to incorrect oil pressure or level readings.
bob2dboat
Same thing happened to my truck tonight, oil all over the ground, and I had the truck towed home. I will try to figure out where the oil is coming from this weekend. I saw the oil pressure gauge dropping and I pulled over and shut the truck off. I hope the bearings are still ok. Anyone have photos of the turbo oil lines?
BTdriver
153
65
Sorry, no pics, but there is one turbo oil line that goes from the turbo down the back of the engine into the block just above the trans. The other oil line to the turbo is fairly short. If either of these lines failed, oil would run down the back of the engine and sides of the trans bell housing.
MrB616
26
If it is the plug on the drivers side attached to the top of the oil pan, it is the crankshaft position sensor wire. The turbo oil drain line is pressed into a rubber grommet and the pressure line is a banjo bolt next to it just above the transmission
