2016 Dodge ram 1500 ecodiesel loosing coolant
Dennis Keith
I know this has been discussed but here is my dilemma
1 pressure check was great
2 found a little coolant coming from overflow changed cap
3 No leak found anywhere
No overheating or codes
Oil temp 206
Coolant temp 203 to 206
Still losing coolant .
Please help
Scottd
78
25
Oil temp 206
Please help
It’s likely your EGR Cooler is putting the coolant directly into the intake of your truck. It’s a known weak spot on the modern diesel motors.
Skylar
24
How much are you losing? I have 134k miles on mine and it seems to be sipping a little, but nothing alarming.
Sent from my SM-G965U using Tapatalk
Skylar
24
Also I just cleaned my EGR pipe and didn't smell/notice any coolant.
Dennis Keith
Its down bout 1/2 inch a day i drive 15 miles a day work but it looks like some is coming out the overflow i just dont know why
Skylar
24
Does your oil look milky? The oil coolers are notorious for failure.
Scottd
78
25
History says that if your oil cooler fails it will put oil into the cooling system. Not drinking coolant.
Scottd
78
25
Do you add coolant everyday? Is the level below the seam in the degas bottle?
Skylar
24
Guess that makes sence if the oil has the higher PSI.
Scottd
78
25
EGR cooler leaks are misdiagnosed far too often. I think the easiest way of seeing if it’s leaking is to pull the EGR tube and see if it’s wet with gummy soot. It should look like a dryish black soot powder. Not gummy.
Dennis Keith
Its at the seam in the bottle i filled it to the cold fill line last Wednesday .what ya thinking
Scottd
78
25
That’s good news....watch it for the next few days/weeks. It’s my belief that our degas bottles are mismarked. Almost everyone that I’ve talked to including myself has there coolant level settle at the seam in the bottle.
Mine will be at the seam when cold, and when the truck is up to normal temps my bottle is at the top of the cold fill mark on the bottle, due to expansion.
Mine has been at the exact seam for three years now. I originally got worried when I saw it the first time and added coolant to the top mark, and then about a week later it was back to the seam.
There is a hose in the bottle that ends at the top seam. You can’t see it but it’s there, and when the coolant expands it goes above that open hose and drains out of the hose which runs out directly under the center of the bottle, and that hose dead ends below the radiator, so as you’re driving it is leaking out that hose and onto the road, so there is no real evidence of it in your driveway.
Just a theory of mine. But I wouldn’t worry too much as of right this minute. Just stop adding coolant for a few days and see if the level is at the seam before you start it every morning for the next few days.
Dennis Keith
Will do i will let ya know in a few days ty
Scottd
78
25
If it gets below the seam...you likely have a leak somewhere. And my bet would be the EGR cooler.
Dennis Keith
What do you think would be better to do if its the cooler delete it or fix it
Scottd
78
25
If/when mine starts leaking it’s coming off within a week. I live in Louisiana, so no crazy diesel testing for me.
I have a 2015, so I’m out of bumper to bumper warranty, so it would be around 2000 to replace it.
If you’re within warranty I would let them fix it by replacement, and then delete it. A brand new one would be worth a pretty penny to someone.
Dennis Keith
Afraid the warranty for the egr is 36000 my truck is at 38k so sucks for me
694
Find another dealer complain about truck is pulsating and losing coolant, they will replace the plenum and EGR Cooler. Mine was done at 43K miles
  • Ecodiesel EGR_Intake Repl 11 7 18.pdf
