2016 Ecodiesel 100% Full DPF P0428 Cat Temp Sensor RESOLVED
krhd1113
Hi all,
I recently got 100% full dpf see dealer warning. I connected my AlfaOBD to force a regen but it would shut down after about 5 minutes due to a cat temp circuit high P0428
the graph showed the cat temp steady around 630c then a straight shot up to 999.9c and shed idle down and quit the regen
instead of running out to replace the sensor at $200 cdn a friend advised to clean the egt in the manifold as this soots up and can mess up the cat temp sensor reading.
so I pulled off the passenger side plastic wheel well liner and I was staring right at it. You can see in the attached image the sensor above the dpf going into the manifold.
I soaked this with wd40 and got it quite easily (and I'm at 258,000km) I put a red solo cup with diesel and soaked it for at 30 minutes, wiped it off, hit it with the air nozzle and re-installed.
for good measure I put a high speed fan underneath my truck to cool the dpf - my thinking was I might keep it just a few degrees below that point of no return temperature that failed the temp sensor.... crazily enough this worked at holding down the temperature about 20 degrees and it slowed the climb up to 630 degrees significantly
anyway, I forced the regen and this time in completed! within 20 minutes my dpf was down to 10% soot load and all codes cleared.
The best part is this cost me NOTHING! $0.00 !!
obviously I am going to keep an eye on this now but for today my truck is back on the road and my wallet is no less empty as it was before this happened.
I hope this can help others who have had a similar issue
nickdieselz
The Exhaust Gas Temperature (EGT) sensors can indeed get fouled up with soot over time, especially with high mileage like your 258,000 km, which can result in incorrect readings like the 999.9°C spike you saw. Cleaning the sensor as you did is a good, cost-effective solution that can often prevent the need for a costly replacement if the sensor itself isn’t actually defective.
Your method of using a fan to control the temperature during the forced regen was also creative and shows that sometimes a practical workaround can save the day. Now that the DPF is down to 10% soot load and the codes are clear, it sounds like your truck is back in good shape.
Just be sure to keep an eye on those temperatures and sensor readings in case the issue resurfaces, and regularly monitor your soot load to avoid any further complications. This type of preventative care can go a long way in keeping the emissions system functioning without additional costs. Thanks for sharing, and this will surely help others who might face similar DPF or EGT issues!
krhd1113
UPDATE: ok so 2 months has gone by no issues.... UNTIL this week. DPF 100% blocked again. I ran a regen (after several failed attempts) and was good for a couple days then back to 90%.
I hooked up AlfaOBD and the catalyst temp sensor circuit high (bank 1 sensor 1) was back but this time the failures were excessive, the alfoOBD graph looked liked a heart rate monitor.... up/down/up/down repeatedly 450 to 999.9 and back down to 450(ish) then back up 999.9
Of course every time this happens it kills the regen. So I purchased a new temp sensor Mopar 05146662AD and replaced. this is the sensor at the top of the DPF, its relatively easy to get at and even with 260,000km I had no trouble removing. I have attached photos of the alfa graph, the part with packaging and the diagram.
If anyone gets this error and sees this kind of activity in AlfaOBD with the Particulate Filter gas temperature sensor, this is the part you need to replace.
Anyway, after I installed I forced a regen and I knew immediately it was going to work from the graph in AlfaOBD, i could see it was a better temp read and thankfully I was right as the regen completed first go without issue.
FlyEco2122
I hope this helps anyone dealing with this issue themselvesView attachment 4445
Great post! Very informative and easy to follow. How did everything work out after you replaced the temp sensor? I'm running into the exact same thing. I run a forced regen only for it to shut down after watching the catalyst temp sensor spike too 999.9 for a split second right around 630° C. Thanks!
krhd1113
no issues at all since replacing cat temp sensor almost 2 months ago. (touch wood). the only exception being the very next day i had to clear a code for the NOX sensor but that was a one shot deal, maybe all the failed regens etc caused something not sure, but like I said it only happened one time the next day and since then no more engine light. Just in time for winter.... my remote start works again!
back to you though, yes if your temp sense failing and maxing a 999+ temp reading that is precisely what my issue was. initially it only happened occasionally and I was able to force a regen and buy a couple months, but you can see from the graph image above it began failing repeatedly every couple minutes. I suggest replacing the temp sensor now and be done with. up here in Canada was around $250CDN, didn't take long to swap out. Let me know how you make out and good luck!
FlyEco2122
So finally got enough time to swap out that sensor last weekend. Found it on Amazon for $35USD! I had my doubts that it would work, being as cheap as it was, but once I swapped it out, I ran the forced gen with no issues. I was over %200 when it initially started so I actually had to run the regen twice. The first dropped to %140 and the second dropped to %75. I've been monitoring my soot levels daily for the last week and am sitting at %20 as of yesterday. This also solved my check engine light issue I've been having trying to get the truck to pass our country's "awesome" emissions test since once you clear the codes, it puts the ECU into a "Not Ready" state when they hook up their reader. Really appreciate all the info you had on your posts and the follow up posts. Thanks again!!
kruppa13
Do you happen to know the part number of the first sensor you cleaned or is it the same one you replaced?
