Back up lights
John K Sr
I have a 2016 and would like to add some LED back up lights to it. I was thinking of tapping into the trailer wiring to get the back up light wiring, to avoid adding relays. Has anybody added additional back up lights to their truck and if so, how did you do it.
867
427
I mounted two 7" cubes/bars as backup lights and tapped onto the backup light wiring at the rear of the truck. Working fine, no problems.
Welded tabs onto the hitch tube to get the lights up high and further back. Here's a pic of the radio screen at night.
1918
Lou
26
Instead of tapping into the wire harness you could just wire them into a 7 pin connector and plug into the trailer connector.
Also you could rplace the backup lamps with led's, I got mine from amazon and they help considerably.
AUXITO Error Free 912 921 T15 LED Bulbs 2000 Lumens Extremely Bright Newest CSP 9-SMD Plug and Play for Backup Reverse Lights, 6500K White (Pack of 2)
Price: $34.99
John K Sr
Hi John, I thought that tapping into the factory backup wiring would cause a problem with he CAN BUS, whatever that is.
I figured tapping into the 7 pin connector wiring would skirt that problem. I like the idea of welding tabs. I may do the same so as to try to keep the new lights as much out of sight as possible.
I was going to try the 4 bulb cubes that Harbor Freight currently has on sale for $20.
Hi Lou, I thought of that, but I didn't want to wire into a 7 pin plug because I didn't want to have it sticking out of the connector all the time.
Did the LED bulbs you put it really make a substantial improvement?
I feel that the factory backup lights are marginal in dry weather and completely useless when it's raining.
The halogen headlights preform pretty much the same, but that can be fixed if I want to spend a good size chunk of money and time.
I love my truck now if I could see where I'm going... :)
867
427
I've had no CANBUS problems. Thought I might because they are cheap LED lights. Here's pic of a tab and of lights mounted.
19201921
John K Sr
They look great. Where did you get the lights?
How/where did you connect the new lights.
867
427
Can't remember, had them laying around for a while. Probably off eBay
See post #2
John K Sr
I'll have to check out ebay for lights. Yours look better than the ones at Harbor freight.
Lou
26
Yes the led backup light replacement bulbs make a considerable difference.
TexasRed
Check out superbrightleds.com for vehicle specific lamp upgrades. They have a wide variety of options, fast shipping, good warranties and competitive pricing.
