Check engine code P0087
LuisW35
27
13
I just got a check engine light that came on while i was driving and right away took it to get it checked. Turns out it’s low fuel pressure. Any suggestions to take care of this before anything else can happen?
It’s all stock only have a pedal commander installed. I’m very new to diesels any suggestions will help. Thank you
vandan
53
14
get yourself an ObD2 reader that way you can delete it and carry on driving but make a note on what your deleting that way if you do have to go to dealer you have a record of it. This would be a good investment for you and could save you a lot of trips to the dealer for what they will do anyway.
vandan
53
14
They recommend to change fuel filter every second oil change or 20,000 miles
vandan
53
14
if you have a code reader and you can delete it why not but make a documentation of it
LuisW35
27
13
Thank you. Ill do that
283
If u drive around with low fuel it will Hurt the fuel pump like 1/4 tank
vandan
53
14
yes because the fuel keeps your fuel pump cool that is for any vehicle that has fuel pump in the tank
vandan
53
14
I don't let mine go under a quarter tank especially in the summer time or winter,you don't want to get stranded
LuisW35
27
13
I never get lower then half a tank today i topped it off
vandan
53
14
have you tried Xp3 additive seems to increase my fuel range I just did 3 tanks and it seems my range has increase by at least 100 klm.
LuisW35
27
13
I have not but I’ll pick some up.
LuisW35
27
13
Thanks guy after replacing the fuel filter the check engine light went away
Wesley Lantz
I have the same code along with a pressure loop code new fuel filter. runs very sluggish and even stalled twice. at dealership now will post update anyone else have thi issue
Gav4life
Most likely you will need to replace the low pressure fuel pump. I just got my truck back yesterday after fixing the same issue.
First, replaced fuel filter but during test drive truck stalled and had to tow back in to the dealership.
Technician tested diesel low pressure side and it was only 40psi and the minimum pressure required is 60psi ( this is for low side only)
High side pressure is like 2900psi
But after replace the low pressure fuel pump truck is running fine so far.
Total damage: $1550-cad (diagnostics, fuel filter, low pressure fuel pump)
U can save ..just order original low pressure fuel pump from Mopar online website. It’s on sale for $328. Find good diesel mechanic and have him replace it for u.
bigredaggie
Thank you posting this. I have a 2014 JGC ED, 120k miles and it popped P0087 and P1292 (CNG Pressure Sensor High). It was driving normally without issue, good temps and power. I used BlueDriver to monitor the available fuel system parameters and was able to see that the commanded fuel rail pressure was right on with the measured pressure (~4000 to 17000 psi depending on engine load). I followed the troubleshooting steps on your service ticket and replaced the two fuel filters, primed the pump about five times, and then cleared the CEL. So far so good driving fine and the CEL has not returned. The Jeep needed a regen but it wouldn’t initiate due to the CEL. But after clearing the CEL it initiated regen right away and finished on the highway business as usual. I don’t see parameters in BlueDriver to monitor the low pressure fuel pump pressure, but I’m not having the stalling issue that you did. I still don’t know if changing the fuel filters actually solved it, or if this was just a momentary hiccup with either the fuel system or one of the sensors and I could have just cleared the CEL and moved on, but I don’t know the last time the filters were changed so it was 80 bucks well spent either way. Very very simple job if anyone is considering it. I was warned by a friend that modern high pressure fuel pumps tend to fail in such a way as to send aluminum shrapnel into your fuel system and damage everything downstream and that driving with a failing pump is a ticking time bomb. I’m interested to know if anyone knows and more “home diagnostics” I can do to validate the HPFP is okay besides just looking at the delta between commanded and measured fuel pressure via OBD?
