Coolant issues
Andrew2012
Need some help guys. I have a 2014 eco just almost 102k miles on it. I have just ran into a coolant issue had an engine code come up waiting low coolant or bad thermostat. Added some coolant was a tad low but not bad at all. I have my egr system deleted. Today I get home from work and there is coolant leaking ineervmy truck. Reservoir hasn't dropped a bit. I have read on here egr systems have been an issue since mine is deleted where else could my problem lie?
283
welcome 2 the group if u can't see a leak it could b the turbo cooling hose
Andrew2012
10 4 I will check into that. Where is the turbo cooling hose located?
283
under the intake manifold I think the job at the dealer ia around 250 for hose 2000 to install
