Coolant leak
Milvetmac
69
Water pump was leaking... turned out that was only a part of the problem, ended up having to pull the whole upper intake plenum off, cleaning the egr and map sensor and the turbo coolant inlet line under the intake. And the intake alone took almost two hours to clean by itself and almost another hour on the egr. It was about a week worth of work and a thousand bucks but that stupid turbo line was the main culprit. 300$ just on that small line by itself so I put a dei titanium line cover over the rubber part and havnt had a coolant issue since.
