Def for ecodiesel
RamToby
Is there any difference in the quality or performance of def fluid from one manufacturer to another. eg. Reochem vs Mopar?
238
43
Blaine
www.tcdiesel.com
The API cert is 32.5% Urea 67.5% Deionized Water. I mix My DEF in My 2015 for three years with distilled Water, You can mix Your DEF if you like there's NO law or EPA rule, Just a Cert. My data showed 10-17% Concentrate of Urea dropped the NOx to near 0 95% of DD use. I never had any trouble with My DEF system in My Eco the 3.5 years of Ownership. the Urea is the culprit when DEF systems fail.
Hmm I been doing this for years in all My DEF Trucks, DEF Cert is a Hoax for $
238
43
Blaine
www.tcdiesel.com
RamToby, this is Me, I did the same to My eco for 3 years. I mixed 2 gallon of distilled water to 2 Gallons of DEF at 32.5% this dropped the Urea levels below 16%. I've ran as low as 10% during summer months < I have never had a DEF code in any of My owned trucks in 10 Years.
Reactions: John Jensen
182
88
85
San Diego County
www.johnfjensen.com
TC,
I'm in Oregon elk hunting and trout fishing. Every morning has been 8 degrees to 27 degrees. Just before I left San Diego I topped my def with 2 gals of distilled water that brought it to just overflowing. the tank by approx 2 oz.
I was a bit concerned when the first morning it was 8 degrees. I'm tuned so the water is okay but I was sure concerned about freezing. No freezing & problems!
TooClose Racing
Guys - this is an interesting topic. If someone could please expand a little bit on the Negatives of going with standard DEF vs. diluted DEF, much appreciated. I think I've convinced myself after reading a couple tech articles (and John has helped...) that I shouldn't be concerned with freezing at the lower urea concentration. Has anyone done any kind of study/review that I can find on the Internet? Thanks!
238
43
Blaine
www.tcdiesel.com
I have use different levels and tested the NOx, Back in 2015, Back at that time I saw no need to keep the data, Dec/Jan 19/20 I will be leasing the fuel analyzer again this time I will post the data.
Back in 2015 I posted the Eco would fail CAA and 1.5 years Later the EPA agree with Me. and file the Case in FED Court.
32.5% is very potent and in certain conditions will crystalize, causing the vehicle to enter de-rate mode and in many cases $1000.00-2000.00 in repairs.
Image result for crystallize def injector
hossman
I have a better solution than adding water. Doing a full delete this weekend. HD diesel supply as a good kit. I will do a post once I have a thousand miles on it.
182
88
85
San Diego County
www.johnfjensen.com
TC,
Reactions: hossman
