Drivers Side Rear Indicator Light: Intermittent Failure
Gossman78
48
Has anyone seen the intermittent failure (and subsequent alert in drivers information center) regarding the Drivers Side Indicator (turn signal) going out? The Turn signal actually flashes faster when the truck thinks the light is out. But, depending on turning the truck off and on it'll fix itself. I'm sure it's a ground somewhere on the CANbus. UGH..
8v71
43
22
Yes, Mine dose it when I run in very heavy Rain, then after It dry's out it is fine. I blew a right rear tire at about a 1,000 miles and shattered the mud flap, that's when I noticed it the first time. I am at 129,000 miles now and it still will do it occasionally. I have never bothered, but I think that a little silicone around the light socket will probably cure it for good.
