Electronic Throttle Control ETC with SFT
Karolus007
SFT tune no code just service electronic throttle control came on. So far I cleaned the MAP sensor and no luck . I’m going to do a smoke test next to see if there is any leaks. Truck has been running great since the tune(stage 2) a few months ago. Occasionally I would notice when I turned it on it would show that light but quickly turn off and work fine(seemed like a weather thing cold). Now all of a sudden it’s on and staying on. I did send SFT an email, waiting on response. Also ordered a MAP sensor and a gas pedal. Both pretty cheap so I figured I’d give it a go and see what happens.
Karolus007
I read all the threads, I do t think there is one I missed on the issue..
ecodieselidiot
Did you remove the tube that goes from the turbo manifold to the egr at the manifold or did you block it off on the top. I blocked mine off on top because I rounded a bolt off of the other end. Then after a few months it broke the tube.
Karolus007
I was going to leave it originally but then went to remove. I read a lot of posts about it cracking so decided to remove it. While removing it I broke one of the them. I put the cover on with 2 bolts and one screw on the broken of bolt. Worked like a charm. So far so good, and moving forward I’ll clean the map sensor every oil change not to have any issues.
