Engine Rebuild-Wisconsin
Tree Man
19
2015 Outdoorsman, Pushing 235 K on engine and want to be proactive. Live in the middle of Wisconsin and looking for the best shop that is known for rebuilding the Ram 3.0 eco Diesel engine and transmission. Not afraid to travel to get a quality shop. Have replaced many parts over the years along with warranty work, and In my mind price of a new truck justifies replacing the engine/ Transmission.
Thank you
4,368
1,158
Are you having issues today? Also, some trucks are damn good trucks.. in this case 235K and it's still together is not a bad thing. Some don't make it 10K :D Either way, I do admire you trying to find someone that knows these through and through. You'll probably have a better experience that way then dropping in a new one.
Tree Man
19
Thank you for getting back to me. No major issues. Driving two hours at 70mph / 75 degrees outside not towing anything, the oil temp is holding at 224 degrees, trans temp 170 degrees and coolant temp is 210 degrees. The model is the Outdoorman that has a trans cooler. I'm wondering if these temps are normal with 235k miles on the engine.
BTdriver
145
61
Temps: The thermostat is 208°, so you're good there. 170° on the trans is good; mine runs 180°-185°, but I don't think I have the trans cooler. I'm not specifically recalling what my oil temp runs but 224° sounds about right.
-2015 Laramie ~180K
734
I would just continue to drive, and revisit what to do if problems develop, the diminished valve is NOT worth the truck value W/ new engine. Changing Engine for One that worthy IMO is NOT worth it. My 2019 Hemi cost $2.200.00 Les to operate in 6 years than My 2015 3.0 in 4.5 years of ownership, my 2025 Hurricane hopefully will cost less, it's getting 20-22MPG at 65 MPH and City 16.5 -16.8MPG HC. The Hurricane is an amazing powerplant and surpasses the VM 3.0 in every category. With Gas being .50-.60+ less than DSL and risky maintenance $$$$. IN MN the 1/2 Ton Diesel don't even pencil in ownership.
Tree Man
19
Thank you, I will run the numbers and try and put sentimental attachments aside.
