Fuel Filter correct one?
RandyK
2014 recently purchased. changed fluids and all filters.
The filter on the left is the one i removed.
when I order new ones, and went to Dodge Dealer, I get the one on the right that says it is the replacement for the AA.
The one on the right is almost 1/2 inch shorter than the original.
I questioned at the Dodge dealer and they said it's the one called for. Used VID number at dealer.
Does the difference in length not make a difference?
Thanks
Frank246
111
29
Yes. I questioned the same thing and told by many eco drivers that this is the new style. I will be installing mine in about three weeks so I guess I'll know for sure then, but VanDiesel in Ohio who knows everything about these engines says it is the new, correct one.
RandyK
thanks for the reply.
But no explanation about the dif. in length?
I'd sure like to know.
Thomasjay
Just a heads up when you do change your fuel filter. Make sure you put the filter all the way on without the cap. It is tight, just a warning. But it goes on all the way. Just had to reset mine 3 times before I got it all the way up. Also make sure bottom blue gasket on filter is seeded secure before you put cap back on. Hope this helps.
819
309
I too compared the filter side by side and while the new style is indeed a little shorter it is also a little larger diameter. I assume it has the same amount of surface area.
