Glow plug issues
evad30
PA
Hello, I have an issue I cant figure out.. Started with GP#4 CEL, replaced it.. good for a couple weeks.. CEL back on for same plus P06BC... Ordered and replaced the controller.. Fixed... for 2 days.. CEL back on for all the same.... Anyone else have this issue and if so what was the fix?? Thank You
Supporting Member
Feb 15, 2019
576
224
43
Partlow, Virginia
Sounds to me like the wiring may have an issue. P0674 was my code along with the p06bc. If you continue to drive it do anymore codes come along?
evad30
PA
No other codes... When I clear them, It may go a day or so... then back on
Supporting Member
Feb 15, 2019
576
224
43
Partlow, Virginia
Mine would go a few days without throwing them, longest was a month. I’d check over the wiring and see if you see anything out of the normal. Unless the glowplug out of the box was bad or the connection on the glowplug itself is sloppy and not making good contact
evad30
PA
This vehicle is so hard to find information on.. No wiring diagrams.etc.... Unless you spend big $$ for the service book on dvd
Supporting Member
Feb 15, 2019
576
224
43
Partlow, Virginia
Tell me about it lol start at the plug and trace your wiring harness back. Unless you changed the wrong plug out which could be a possibility too
evad30
PA
Negative.. it said plug 4... front drivers side... I did check it with Ohm Meter,, was at .4.. which new one read .2 I dont think it was even bad..
evad30
PA
Ok, I metered the plugs... #1 plug was .221v and plug #4 read 124.3 mv... I put new glow plug in and grounded it... it lit up.. I put the old old in the plug and grounded... did not lite!! I see there are several different part numbers for the same looking plug..The one I used first was only $21 on amazon.. I ordered another with a different part number from Amazon and it was $57..
Supporting Member
Feb 15, 2019
576
224
43
Partlow, Virginia
I went to the dealer for mine. It was around 60-70$ I may still have the receipt with the part number but I doubt it
