Just a thought....
Sledneck52
My 2016 takes forever to reach operating temperature. 190 or higher. It was 31 degrees outside. I let it idle for 5 minutes or so before leaving. It didn’t even register past 100 degrees. I drove it for almost 25 minutes and it never past 174 degrees. Stop an go, driving through our town. I took control of the trans and shifted myself trying to keep the rpm’s up.
Didn’t make a difference.
I don’t have the cold weather kit but it shouldn’t matter at 31 degrees.
This would almost certainly cause DPF clogging problems if you can’t get the engine and exhaust to operating temperature.
I wonder why these motors take so long to reach operating temperature? 🤔
Bookmaker
24
Because diesels are very efficient. More energy from fuel converted to work. Less converted to heat.
380
133
My 2014 always is slow to warm up. I have the radiator louvers, but I have modified to allow for external oil cooler fan. I will plug in block heater anything below the low 30's. Mine tends to get to about 147 and hovers until highway speed then warms up to 201. I have replaced my thermostat and a GDE tune. With the single core radiator I had thought it would warm faster but no. It is a good thing most of my driving is highway speed and the GDE tune greatly reduces the soot production.
914
333
Technically you should be running the assless chaps leather grill cover that FCA reccomends for anything under 50F but mine did fine today at 20F around 50mph
Ecopete
166
Was that towing anything?
This is just my 2nd winter with the eco and I just bought a cover for it 2wk ago and put it on. Wow, what a difference! Not sure how to know when to take it off when it turns mild though.....
Will_CathVT
77
24
I'll start with, I live in VT. I always put my grill cover on when it's going to be under 32 degrees, I close the flap(s) as it gets colder. I plug in the block warmer when it's going to be under 10 degrees. I have the block warmer on a timer that is set to turn on two hours before I drive the truck. I drive secondary roads and average 50-55 mph, it takes approximately 20-25 minutes to warm up no matter the exterior temperature. I keep my engine and transmission information on my DIC. I haven't had an exhaust plug since two days after I bought it...been fine since the 2 exhaust sensors were replaced and the EGR cooler a couple of months after that. I don't use the truck for a lot of short trips, I use the wife's SUV.
bill-e
82
40
My Gen 3 seems to warm up a lot faster than my Gen 2 and operating temps are higher as well.
Normally I'd have the Gen 2 cover on by now because it was such a PITA to get those bulbous tabs under the grill but my 2020 cover doesnt have them so I'll wait until it's going to not get above the 20's before I put it on.
