Need help on purchasing ecodiesel
MRGT
So i am purchasing an ecodiesel and my shop noticed that there is no cat or dpf. He said it looks clean install so we are both guessing previous owner bought a kit. I am trying to determine if it was done well and right. I am guessing that we should also check
DEF
ECU - piggyback or flash???
EGR
Is there a way to tell what brand was purchased?
many advise before I purchase truck.
it’s a 2015 ecodiesel Laramie longhorn.In Canada, 150k kilometres or 90k miles
914
333
DEF
EGR
My guess would be gde or something similar. You could drive it and if it throws up a Regen screen it could be gde. If not it could be either gde or sofakingtuned. I suppose you could contact either green diesel engineering or sofaking and see if they have the trucks vin in either of their files.
MRGT
My major concern is if the work was done well and right. Also if the ECU was reprogrammed and if it wasn’t can I damage anything. I have some pics. I also found out that DEF is disconnected and the O2 is unplugged
914
333
If it wasn’t tuned you would have every light in the dash lit up like a Christmas reee. The delete itself is pretty straight forward
MRGT
Is there any way to determine what was done?
4,288
1,127
Sticker on the ECM maybe? Otherwise not without some expensive equipment to pull the tune and see what's there... even then you'd need the skill/experience to know what you're looking for.
914
333
Refer to post 2 on this thread. Truck is tuned contact who manufactures tunes for these engines and see if they can look up the vin.
1,050
422
Is the EGR intact and blocked off or completely removed?
MRGT
The EGR is capped, electrical connectors, and vacuum line plugged. But no external programmer found.51631CC3-902C-4675-8EC3-3B8705385DF0.jpeg496DD24F-259F-4426-8042-67DE62D6C7D5.jpeg
MRGT
The place I am buying it from may take it to a local tuner to help figure this out. So Far I know that GDE did not do it
Mac
43
I love a good mystery! I just bought my first ecodiesel about a month ago and had a GDE tune done. the device they gave me can look at the program on the ECU. Maybe there is a shop with a similar devise that can look at the program Information on the ECU? Just a thought.... good luck and let us know what you find.
