Need Help Transmission wiring harness
Propaganda26
I’m hoping someone can help me in answering compatibility question on the Ram Ecodiesel Transmission Wiring Harness. I own a 2015 Ecodiesel and my harness melted from a clogged CAT/DPF system, warranty will cover that emissions items but not the harness. Dealer wants 3000.00 for just the part. I found one from a 2014 Ecodiesel but the part number is different on the original a harnesses, but all of those original numbers have been discontinued and now the transmission harness ends in AF says it’s compatible 2014-2019. My question is will a original 2014 harness work on my 2015 ram. Everything else about the trucks match other then the year
915
333
I’d assume as long as you have the same trans and t case if 4wd it would be the same. Part numbers change as the years go on so it could just be a wire color change or something simple
