new guy from florida
KevininStuart
hello i own a ram 1500 4wd with ecodiesel ! it is currently at the dealer with the "service electronic throttle" warning light
283
Welcome that is where all un tuned Eco diesels end up time after time gde it
cds13ca
216
76
welcome, get it GDE tuned, probably a choked up MAP sensor, or too much soot in your intake. With a tune, it'll disable the egr and reduce the soot bigtime, improve your mpg, reduce your regens significantly, run better, run cleaner, keep your oil cleaner...
693
Very common on the 3.0, In long term ownership its either tune or get use to that Message.
cds13ca
216
76
GDE unless you are from california as they can't sell to cali...
KevininStuart
I picked up my truck from the dealer on Thursday afternooon ! The problem seems to be resolved ! The check engine light was a result of "low turbocharger outlet pressure " resulting in the reduced power and causing the throttle to open further than normal causing the " service electronic throttle linkage" light ! I drove te truck at highway speeds for about 500 miles in the past couple days and all seems well ! the DEF tank level is noticably lower , so I believe at least one regeneration cycle was completed ! Kevin
693
DEF level and usage cannot determine Active Regens...Outlet Pressure is determined by the SCR and Intake sensors. Was Turbo or Intake replace, if NOT and a through work over it will be back.
