P04db
Castaxe
19
How hard is it to change the oil cooler and these engines? Went on a 4 hour road trip yesterday and had code p04db pop up for crankcase ventilation. I have been running a cft catch can for the last 2000 miles, checked it and it had a few drops in it.l so it wasn't full. My coolant doesn't look black but it does look a little darker than it used to and there is some black sludge stuck to the top of the reservoir. EOC stage one tuned and egr cooler recall done. Cleared code and it went away so we will see if it comes back. I'm suspecting oil cooler is about to go. Maybe the egr cooler is bad? Thoughts?
914
333
I had this code after upsizing my tires. In my research I found catch cans seemed to be the main cause of the code. But I don’t have a can do I started retracing what the hell would cause it all the sudden. The only thing I kept coming back to was the damn tires. I noticed especially when pulling a trailer my transmission would kinda lug the motor and I would get the code. I found manual shifting to eliminate the problem for the meantime. Also got it on a back road doing 55-65 seemed like rpms went low and unless I feathered pedal to get trans to shift it would throw the code. I was fiddling with my tuner one day and I Reset trans clutch values a few times and it hasn’t came back yet.
Castaxe
19
I am still experiencing this code off and on. I've driven the truck around 8,000 miles and done and oil change and I have had no oil in the catch can. This code will also trigger anytime I part the truck on an angle sloping up or down in relation to the front end. I have also had this code trigger after going through the car wash. Stock tire and wheel size. I'm stumped.
