P2455
Castaxe
19
Just had my reluctor wheel and crank sensor replaced. When I got the truck back the mechanic told me I had a code p2455 that wouldn't clear. Diesel particulate pressure sensor circuit A high. Took it out on the highway for about 30 mins and cleared code. Let the truck sit for a few hours and took it for a drive and the code came back. I checked my exhaust bolts and they are rusty but it doesn't seem to be leaking. Wondering if I need to wait for an active regen to fix or maybe something got damaged during the repair. Any insight would be greatly appreciated as I have OCD when I comes to check engine lights and I can't stand driving with one on my dash all the time.
908
331
Possible causes could be
-Failed exhaust differential pressure sensor
-Open circuit in exhaust differential pressure sensor circuit or loose connector contact
-Failed engine-ECU
My guess would be to check all your connections. When they removed the transmission they could have connected something backwards going to the pressure switch or the connection could be poor and when it’s hot it makes better connection
Castaxe
19
Thank you! Now I have somewhere to start. Will this cause any issues with the truck. I spent most of my available funds getting the reluctor wheel replaced. I might have to drive it for a little while with the code until I can buy parts if I have to.
908
331
You may run into issues later down the road should the truck need to Regen, but if it went away and came back it may only occur when the exhaust load is nearing full soot load
380
132
Thanks for the info! I got the code to clear, crawled under the truck and found the plug for the differential pressure sensor wasnt plugged in all the way.
That was going to be my suggestion.
Broxius_Ecodiesel
Really wish there was a video showing where the connections one is looking for for this code as i cant find almost anything on which connections to check!
