Pre-EPA Hot Tuned ECU
forlornlegacy
Hello everyone,
Just traded in my 2016 ED, so this ECU is fresh for the taking!
Here is my order:
Products
1 x Ram 1500 EcoDiesel Hot Tune$1,359.00
-Ram 1500 Model Year : 2016
-Ram 1500 Engine Tune Purchase : ECM Exchange(Refund on ECM return)
-Ram 1500 Axle Ratio : 3.92
-Regen Message : Yes
-Engine Braking : Yes
-High Idle : Yes
-Off-road Tuning : No
-Oil Pressure Sensing : No
-Shipping Insurance : Yes
I will be including 2 stainless steel block-off plates so you can remove the EGR tube, which takes about 15-20 minutes to do depending on your skill level. They use the existing gaskets and just make 100% sure nothing gets from the EGR, because even when shut off, a tiny bit of soot can still get through.
Looking for $750 shipped, will include tracking and insurance and lots of packing peanuts.
EARL99208
If I we agree on a purchase price and I purchase this from you do you know how I'm supposed to get the vin & injector codes programmed on this ECM so that it will work on my truck?
forlornlegacy
Yes, I just went through this programming a stock ECU to work so I could pull this off before I traded it in. It is relatively easy with a phone, took about 20-30 minutes tops between swapping the ECU and re-programming the VIN/injector codes in AlphaOBD.
EARL99208
I'm going to keep this in mind and continue to gather funds to eventually buy a tune for my truck. I'm pretty sure that your tuned ECM will be gone before to long, but I'll keep an eye out to serif it sells.
Thank you forlornlegacy
forlornlegacy
No problem! Hopefully it's still around by then! I have no problem walking you through the process over the phone!
