Question about UCONNECT SCREEN SETTING
CAVEMANN
388
129
I was going through the uconnect screen and noticed a setting that was something about engine shutdown the two settings were 45 seconds and 5 minutes IIRC, BUT I can't tell that it does anything, can anyone offer an answer. Aiso, can Alfaobd be configured for fast idle? I've seen a couple of aftermarket kits but they're about $250.00 that I'd rather not spend!
• Engine Off Power Delay
When this feature is selected, the power window
switches, radio, Uconnect Phone system (if equipped),
DVD video system (if equipped), power sunroof (if
equipped), and power outlets will remain active for up to
10 minutes after the ignition is cycled to OFF. Opening
either front door will cancel this feature. To change the
Engine Off Power Delay setting, press the “+” or “-”
button on the touchscreen to select your desired time
interval, and choose from “0 seconds,” “45 seconds,” “5
minutes” or “10 minutes.”
694
No, Ramp/PTO VIA cruise control buttons cannot be enable, its not like the Cummins, Maybe its available with tuning, I just don't know for sure.
CAVEMANN
388
129
OK, thanks guys, I may dig thru wiring diagrams & see if it may be accomplished wit an SP/DT toggle switch & rheostat.
