R.I.P. EcoDiesel / NEVER EV
MXDPA
14
My 2016 RAM EcoDiesel destroyed itself 2 days ago. First I felt a vibration then a minute later the oil pressure gauge fell to zero. I pulled off the road immediately and found I had lost all the engine oil. Once AAA got it home I pulled the oil filter and found it to be full of chunks of metal.
I have been faithful with oil changes before it needed it, using Rotella T6 and Mopar filters.
I am now have a very hard time finding anyone to replace my engine. I will probably find an engine and replace it myself.
To make matters worst, while searching the web, I came across a video of a car show that had someone from Chrysler saying that they will discontinue the EcoDiesel at the end of 2023 and start producing EV trucks! I was furious! I'm done with Chysler!
4,288
1,127
The trend right now is EV for sure.. but, still years away. Either way, these motors will last forever and be one of the best you've ever had, or the worst. There really is no in between sadly.
MXDPA
14
It was great and I really loved the truck up until the minute it destroyed itself.
SeanPwnery
59
Next year's model is getting the Straight-6 Hurricane engine. In all honesty, it's a smart move. Thanks to the EPA clearly proving it has no clue how diesel engines work, the diesel engine's days are numbered being deliberately poisoned with EGR valves. I bought mine back in September, and in all honesty, I'm at a crossroads - should have I went Cummins, or should I have waited for the new Hurricane? Oh well, I'm stuck with this one for 6 years.
840
416
I don't think "the diesel engine's days are numbered", fossil diesel fuel days are numbered. Now that we have renewable diesel capabilities the diesel engine can exist into the woke green future. Here in Califunny the 76 stations (Phillips66 and Conoco) now offer renewable diesel. I have switched to it.
Renewable diesel is a 100% biomass product (it is not biodiesel), totally compatible with fossil diesel. 80+ octane *the federal minimum cetane standard is 40), cleaner burning, minimal emissions, and has the potential to eliminate the need for our EGR/DPF system.
Here's a good read by a company making/refining renewable diesel Renewable Diesel
MXDPA
14
I came across a video from Recklessmotorsportsusa YouTube channel that talks about the crank issues with the EcoDiesel. Their solution is building a stronger crank shaft and rebuilding engines with them. I was very hopeful to hear that someone is actually wanting to offer a fix instead of just doing the same thing and expecting a different outcome. Wondering if anyone else has had experience with this company? I have contacted them and waiting for info from them so I can have a path forward to getting my truck back on the road.
840
416
You should do some searching about that company. There's a lot of hate and bad reviews, then again there are good reports and reviews. Very controversial.
MXDPA
14
Mr. Jensen, I just read all of the posts on Ram1500Diesel.com which included some posts from you. All they were arguing about was the different tune companies. I am trying to find a more reliable engine. There was no mention of engine failures or solutions. I have Sofa King tune installed on my 2016 EcoDiesel and had no issues with the stage 1 with all the emissions parts in place. I put at least 40k miles with the stage 1. With 140k miles I went to stage 2 and removed EGR, DPF, & DEF. After about 1500 miles the engine destroyed itself. When I heard Randy's solution for the engine failure, I thought it made a lot of sense. Up to now, his seems to be my best bet.
840
416
He may be your only bet as I have not heard of anyone else modding the engine crank. I thought the crank failures were due to its bearing failures. So if he fixes bearing issues on a stronger crank that would be wonderful. Let us know your progress and how it turns out. Randy could use some positive reports.
CAVEMANN
388
129
As a former machinist and well versed in vibration principles, high speed balancing and predictive/preventative maintenance I feel a PROPER failure analysis of a decent cross sampling of engines is necessary for a proper reasoning of ECODIESEL failures. I've read of line bore problems, crankshaft flex, carbon/soot in oil gallies, all guesses and not very good ones without failure analysis.
Tito1776
I lost mine due to massive back-pressure. Sudden, and not one other thing wrong with the entire truck. Now, stuck with a 14-16K bill for an engine job. Odometer has 148K on it. I bought it with 98K and changed oil , kept DEF out of danger zone, and never put more than 3K lbs behind the truck.
Furious, disgusted, and only keeping this truck right up until the new engine warranty is about to expire. MASSIVE FINANCIAL LOSS.
SeanPwnery
59
I'd like to see that - what's the timeframe of that going national?
840
416
It's not a national thing. It's up to the fuel companies as to when and where. Washington state now has a huge renewable refinery near the Canadian border but to date has no distribution. There are scattered locations that only distribute to trucking fleets. Neste My is in the process of building a large refinery in California, not sure if they are doing that in other states. You would have to do some Google research to find when or where nationally..
689
Caveman I Hear Ya, the facts are bedplate engines are unforgiving when it come to rotating mass... every spec needs to be dead-on and VM Motori about $500+ million in production upgrades to MFG to current industry standards.
Jager
I'm done with them as well. Just had a used motor put in my GC last week after it blew Xmas eve of '21! Very hard to get this motor and I'm having issues already.
MXDPA
14
It's now been 5 months that my truck has been out of service. I bought a car lift to raise the cab which makes the job so much easier. I then ordered a Gen 3 engine from Randy (Recklessmotorsportsusa). The setbacks were too numerous to get into, however I finally have a Gen 3 (salvage) engine that Randy retrofitted to work in my 2016 Gen2 truck. It seems to run fine so for, but I now have several electronic issues. Cruise control and A/C blower are not working (can't get the A/C recharged). The tire pressure screen and oil temp/oil pressure/ coolant temp/ trans temp screen in the dash cluster are no longer there. I have messages to have the electronic brake sysyem, air bag system & trailer brake system serviced. I understand that all of these issues stem from the Body Control Module. I have checked, double & triple checked the wire harnesses & connections. Fuses are good. I bought an OBDLink MX+, but the electronic stuff is my weak point. I read the discussions on another site (which included some from you) about using AlphaOBD app to reset the BCM, but everyone was talking about changing lights and such things. Is it possible to get back the things I lost with this AlphaOBD and my OBDLink MX+? I'm at the end of my rope!!
817
309
As far as I know you would be the first person to report using a 2020+ motor in a 2019 or earlier truck if that is what you are saying.
MXDPA
14
Yes - I didn't want to go back with an engine that could have the same crank bearing failure as I had with my 2016 Gen 2.
