Rebuilt my ecodiesel
Turboviper
Notice some metal fillings in my oil filter when I noticed the engine had gotten a little louder. Decided to tear it down when my dealer said it would be a minimum of 6 months for a crate engine. Pulled the engine out and tore it down. Found a bad crank bearing. Replaced all crank and connecting rod bearings. Put it back together and she runs again. Big job. Found bearing from King Bearings. Engine is so much quieter. My wife is happy it's fix. She didn't see me for a week.
jcrheingans
Not counting your time, how much are you into it money wise? Also did you replace anything else as a precaution while it was apart?
Turboviper
I've got 35 hours into the job. But took my time to make sure to document the tear down for easier rebuild. I replace all seals, gaskets, turbo, and head bolts. Could not find connecting rod and bed plate bolts. So I used the stock ones. Crossed my fingers. Polished the crank checked clearences and put together. Engine looked like new when I tore it down. I deleted egr 200000kms ago and changed my oil on schedule. Just that one crank bearing.
paulbobo
where did u find the king bearing and what is the part number? thanks
biggrits21
23
That's cool I wish I had the knowledge to do that . Maybe you should start a business doing just that cause I think there's going to be a ton of work for you
Turboviper
It was a lot of work but, especially without a lift to raise the cab.
Turboviper
I pulled front whole front of the truck off. And pulled the front differential off the truck. Then it was actually easy to pull the engine out. Brake booster has to come out.
Turboviper
I had 165000 miles when the crank bearing went. I caught it before any major damage was done.
