Remote Start for 2018 Ecodiesel Laramie
TylerHFD
Has anyone used the existing wiring to install the OEM remote start? I would rather buy the hood latch for $33 and a key fob for $25 than the whole kit for $238. I see the plug under the radiator bar but can't seem to locate the ground wire that needs to be connected next to the battery. Thanks for your help!
TylerHFD
Thanks for the reply! But I can't seem to locate the ground wire that needs to be connected next to the battery. Is it already connected? Was the purple wire already ran through the fire wall and plugged into the BCM? Thanks for your help!
Patrity
52
You would have to program the fobs to your truck too wouldn't you? That in itself is damn pricey.
2015Ram1500
45
I had two remote start keyfobs complete setup and backup steel keys cut for $166. $45 for key fobs from Amazon 😎
TylerHFD
By complete setup, do you mean they setup the remote start function or was that previously installed? Was this at a locksmith?
283
2 fobs 2 keys 1 hood latch a wire30.00 for prog and key cut plus 85,00 for the kit ebay
2015Ram1500
45
My 2015 had remote start they just had to setup the FOBS Yes at a locksmith they have a key programmer that plugs into the ADB port and does all the set up.
