- Jul 27, 2013
- 4,375
- 1,159
- Not Listed
Thanks to @John for extracting this from the docs. I'm sticking this so it's easy to find in the future to locate what parts are now covered under the extended warranty from the settlement.
Consent Decree Appendix E
Extended Emission Warranty
Subject to standard limitations that must be identified to Eligible Owners and Eligible
Lessees, which may set forth exclusions like accident, abuse, neglect, or installation of noncertified parts, and applicable existing warranty provisions that will remain in effect, the
below.
• Catalysts
o DEF Injector
o DEF Injector Controller
o DEF Storage Tank
o DEF Delivery Lines
Cherokee only)
• Parts of the Fuel System
o Fuel Injectors
o Fuel Rail
o High Pressure Fuel Line
o EGR Cooler Tubes
o EGR Cooler
o EGR Valve
o EGR Temperature Sensor
o EGR Cooler bypass actuator
o Oxygen Sensors
o NOx Sensors
o Fuel/Water Separator Sensor
o Particulate Matter Sensor
o Mass Airflow Sensor
o Boost Pressure Sensor
o Crankcase Pressure Sensor
APPENDIX E TO CONSENT DECREE
MDL No. 2777 EMC
Case 3:17-md-02777-EMC Document 484-1 Filed 01/10/19 Page 207 of 224
o Throttle Valve
o Exhaust Temperature Sensor
• Throttle Valve
• Cylinder Head Assembly, Including Valves, Springs, Valve Spring Keepers, Valve Seats,
Cam Bearing Caps, and Manifold Studs (Camshaft and other components of the assembly
are not covered)
Additionally, the Extended Warranty shall cover the cost of any OBD Diagnostic Scan
for malfunctions that trigger the OBD Malfunction Indicator Light (MIL), regardless of whether
the malfunction is attributable to a part that is covered under the Extended Warranty
below.
• Catalysts
o DEF Injector
o DEF Storage Tank
Cherokee only)
o Fuel Injectors
o Fuel Rail
o EGR Cooler Tubes
o EGR Cooler
o EGR Valve
o Oxygen Sensors
o NOx Sensors
MDL No. 2777 EMC
o Throttle Valve
• Throttle Valve
are not covered)
