TPMS Module
Mihall2362
Anyone know where the module is for the tpms system? I have the right front tire registering double dashes and it stays there after every tire rotation. Just wanting to check the connection.
Mihall2362
Nope, on rare occasions it'll read something outrageous like 75 psi. But it's still malfunctioning after multiple tire rotations
Supporting Member
Feb 15, 2019
627
241
If it’s just that specific location of tire, I wonder where the pickup spots for the sensors are and if you could clean up the connection.
Mihall2362
I've looked and looked and all the research I've done on the internet has been zero help. I've unconnected and reconnected multiple connections with no change. By no means am I a mechanic but i should've stumbled on it by now lol
Supporting Member
Feb 15, 2019
627
241
That’s all you can do! These new trucks cram so much crap into a small package that fixing them is pissing in the wind
jrmflintlock
Yeah, I figured it was the sensor in the tire at first as well and figured when I rotated the tires, the missing pressure (my truck has a image showing the pressure of each tire) would move. But it didn’t so I assume it’s the the module that reads the sensor, but where is it. I’ve crawled around under my truck and don’t find anything..
Supporting Member
Feb 15, 2019
627
241
It says they use frequencies… I wonder if the radio is getting interference. Who knows. Also says there should be a relearn button on the truck somewhere
