Transmission
Marvin
Hello everybody my name is Marvin and I am trying to find out about servicing the transmission in my 2016 eco diesel . The dealership said it needs to flushed every 60k the transmission shop said it needs the fluid and pan with filter changed. I am not sure.
Ramman1
125
30
The dealership said flush at 60k? ram says it’s a sealed system with lifetime fluid. I just changed mine at 160k, yes change the pan too, the filter is built into it along with the magnets. After 160k I can say my trans was still working perfectly. But since ZF suggests a change every 50-60k I finally did mine.
840
416
Like Ramman said, it's a sealed lifetime tranny. I'm told that Ram considers lifetime to be 100,000 miles. Unless you are having problems, there's no reason to service it before 100,000 miles.
Marvin
Thanks I think I will cancel the transmission flush and wait awhile to change the pan and fluid.
scoffman
30
20
I would spend a little extra and get the PPE aluminum transmission pan. It holds a few more quarts of fluid, and has a replaceable filter that you can get for $27.00. I would also go off of the transmission manufacturers recommendation on when to change the fluid, which I believe is around 60K-72K miles. I would also recommend using a better aftermarket transmission fluid as it's cheaper and can perform better than the ZPF/FCA overpriced stuff. I use Hot Shot Secret Blue Diamond D6 severe duty automatic transmission fluid, and my truck is a daily driver with 90 mile commute M-F. I've replaced the fluid and filter once since using the new stuff and it looked and smelled like it came right out the of the bottle. I've been really happy with my decision on the pain, filter, and fluid.
This is just my $0.02 so do with it what you will.
Ramman1
125
30
Thanks for the advice, I think the pan with the built in filter is all I will ever need, I went 161k on the first one, I don’t plan on changing the fluid again. All this time I was under the impression that it was a sealed system and “lifetime” fluid. Lol.
I’ve had 7 Rams, This is the first Ram I’ve kept over 120k.
Ramman1
125
30
Exactly what mine said and exactly when I changed mine. Now I’m starting to have issues at 180k, when it downshifts from 3rd to 2nd it stumbles and missis the gear. Anyone else having any issues with the ZF like this?
thanatos74
Scoffman,
Where can I get this PPE alum tranny pan?
Thanks in advance!
Regards,
Rob
