Oil Spec Recall/TSB - Grounds for Class-Action?
cevans
141
90
In late July FCA changed the oil specification for our trucks. All unsold 2016 were to be drained and refilled immediately before sale and any truck that was in for service is to be drained and refilled as well. Without any type of explanation we're left to wonder why all this happened.
I'm thinking that there are grounds for a class-action lawsuit against FCA for this under these two scenarios.
1) The oil specification that was originally used was discovered to be grossly under-protecting internal engine components. This means that for years owners and dealers used a recommended oil that was actually very harmful to their engines. Since engine damage resulted directly from the requirements put forward by FCA, it is my belief that FCA should compensate owners who suffered engine failure and bore the cost of engine repair or replacement AND should compensate all those who used oil according to their recommendation with monetary compensation for future repairs made necessary by increased internal engine wear and/or extended warranties for these owners.
2) The oil specification originally used is fine, however, FCA changed the specification for inventory simplicity and or cost savings. Notably, the new specification for 5w40 has a negative impact on engine efficiency and accordingly fuel economy - these trucks got their EPA numbers under the requirement that they used a high-efficiency 5w30 oil. By changing the oil specification the MPG numbers of this truck have been lowered below their EPA estimates, and FCA should compensate owners for their increased fuel consumption in accordance with previous settlements with other manufacturers such as Hyundai who also needed to adjust their MPG numbers downward years after selling the cars in the US market.
flying7
175
42
Well, it makes me wonder why they changed the spec all of a sudden with no explaintion. Perhaps the opportunity is there but its to early to tell if the switch has caused or will cause any problems for us
cevans
141
90
Well, the class action would hinge on discovery. The goal would be to force FCA to turn over internal documentation about why they made this change. If they knew it caused damage but actively sought to prevent that information from coming out, that would come out in discovery.
bobcat67
223
88
Not completely related, but I have the 5w-40 in mine now and haven't noticed a difference in economy
bobcat67
223
88
The thing that concerns me is why drain the oil out of the unsold trucks, that to me is the concerning part about this whole deal.
flying7
175
42
Something to do with oil cooler failure maybe.. or maybe something worse (internally)??
Brokedownbutgood
289
103
My guess is it had something too due with FCA going away from Pennzoil and lowering maintenance costs. Personally I switched to 5W-40 myself before the change with no noticeable change.
4,291
1,127
That was my first impression. But, if they are draining non-sold trucks oil and replacing it with the new spec that really takes away from the "cost saving" theory.
bobcat67
223
88
I know the trucking industry is already having a hard time with these newer, lighter oil formulations, saw a pic from a kenworth with a newer Cummins engine in it, had been running 10w-30 synthetic blend in it since the first change, cam was completely shot and needed an overhaul at 300,000 miles and it wasn't in town hauling it was OTR, because they drained the oil and replaced it from unsold trucks leads me to believe there is a deeper problem than cost, maybe they had a gigantic mess up at the factory and filled em all with 5w-30 gasoline engine oil, switch to 5w-40 and alleviate a lot of that kind of confusion
Brokedownbutgood
289
103
I was thinking more on the line of lowering maintenance cost for customers. But ive seen enough clean oil analyst with the 5W-30 to be confident that it was a good oil.
MSP548
202
62
What is FCA? And, does anyone have a link to this information? I bought a new ecodiesel 3 days ago and I'm wondering if I should change the oil. I don't trust that the dealer did it.
Fiat Chrysler America. (FCA)
you should have the correct oil since it was purchased 3 days ago, but it wouldn't hurt to ask your dealer to confirm.
just mention TSB NUMBER: 18-078-16 and or RAPID RESPONSE TRANSMITTAL (RRT) 16-064.
  • TSB-18-078-16 Oil Spec Change.pdf
MSP548
202
62
Thank you
4,291
1,127
Welcome to the forum!
Mr Reed
26
Question: If the service bulletin states this is under warranty, shouldn't my first oil change be free? Just asking opinions before I take my truck in. I bought it new the last days of June and now have 5k miles on it.
The dealer I bought this from sent me a service reminder and I have asked about this service bulletin, but have not gotten a response yet. I dont want to walk into the service department blind.
Thanks
bobcat67
223
88
Everything except the oil filter is covered
