Air ride suspension.
Paul Bohnert
My air ride is not working properly. I replaced the blown fuse ( 40 amp. ), and now I hear air leaking back by the compressor area on the passenger rear of the truck. Any ideas ?? I'm thinking broken air line.......bad air shock......?? Not sure. Any advise would be wonderful. I love the truck and have only 77,000 miles on it.
Marc-11
If you pull the liner from behind the rear passenger wheel you can see the compressor and the mainfold block. Some soapy water will tell you if you have a leak at one of those connections. Are you getting any codes or the Service Air Suspension Immediately message on your dash? I just learned A LOT about my air ride and diagnosed it and repaired it. It's not a complex systme but depending on the problem you'll need a few different tools. First question though, any codes? Check engine light? Did you replace a relay or a fuse?
