Anyone have any luck with removing active grill shutters from ecu using Alfaodb?
E evad30 New Member Jan 6, 2021 9 0 Truck Year 2014 Jan 20, 2021 #1 Anyone have any luck with removing active grill shutters from ecu using Alfaodb?
TC Diesel Well-Known Member Jul 14, 2016 2,540 726 Truck Year 2015 Jan 20, 2021 #2 Why, would you want to disable they?
E evad30 New Member Jan 6, 2021 9 0 Truck Year 2014 Jan 20, 2021 Thread starter #3 TC Diesel said: Why, would you want to disable they? Click to expand... CEL on and replaced with new... no luck still do not work CEL on..
TC Diesel Well-Known Member Jul 14, 2016 2,540 726 Truck Year 2015 Jan 20, 2021 #4 My guess you will need to re-calibrate, I've never work with the shutters on ALFA, WITECH yes, See if you can fine the option with ALFA to re-calibrate the Shutters, its likely in BCM/PCM.
