Annoying P24f3 code
Goldenfoot05
Hey all! I have a 2016 limited. It’s emissions present but with a PPEI engine and trans tune.
I have an interesting reoccurring code P24F3 that only shows up when the weather turns cold, then goes away when the weather stays above about 55 degrees at night. I’ve searched and searched and I’ve learned it has to do with the DEF and fuel temperature correlation. I believe the temperatures don’t agree and because it’s only in the cold weather I’m guessing that either one sensor is stuck reading warm while the other is reading ambient. It seems like the DEF temperature sensor is permanently attached to the DEF tank but I cannot find the fuel temperature sensor for the life of me.
Any help, insights or ideas you can give me would be greatly appreciated. Thank you!
