Coolant reservoir full of oil.
Unf…lucky77
2016 Ram Laramie Ecodiesel it has had every recall after VB1 recall ( replace EGR cooler) another check engine light led to replacing the SCR Cat. Then a week later it spent 3 more weeks at the dealership in order to get the DEF system active again. It made it a little over 10,000 more miles for a total 118,000 miles. I lifted the hood to check the oil and found all the engine oil in the coolant reservoir. I could not touch oil on the dipstick. No engine lights or codes showed up. I had recently subscribed to Uconnect in order to keep an eye out for any trouble. I’m hoping it is covered under the extended Emission Warranty. I would appreciate any input or information. The SCR Cat was covered. Has anyone else had these type of problems? I swear if I can get it running just one more time I will trade it sell it drive in the ocean. Beautiful truck drives good but Worst f engine ever made. Nothing but problems.
1,002
350
Oil cooler failure is common. Unfortunately gonna require draining all the coolant and multiple flushes to get all the oil out you can
