Eco smoking
JackedRam
Hi I have a 2015 ram 1500 eco diesel and having problem with a lot of black smoke new fuel pump, and filter but keep getting a RPS code can anyone can help please I’m about to lose it!!
380
133
I agree with Temper126, it would appear to be a fuel injector issue. Is your RPS code for high or low voltage? If high then I would suspect a fuel pressure regulator issue. If low I would go with a stuck or leaking injector, if you are getting smoke through the OEM exhaust I would jump on a stuck injector. My wife's 2015 Jeep GC had two faulty injectors which was causing a constant DPF full condition.
Good luck with your issue, remember the fuel lines are one time use and I have not found rebuilt injectors online yet so limited to new BOSCH.
