FOB
bob1340
79
19
Not a diesel question. My son bought a used 2019 1500 Tradesman. He only had 1 FOB for it. He was involved in a major wreck in his work truck (not the RAM) and just made it out before the truck burnt to the ground along with his only FOB. He won't be driving for at least 2-3 months, but I want to take care of this for him.
Any advice on this? I am suspecting I'd need to take his pink slip to a dealer and start from there? And I suspect that would be an expensive trip.
So we have a nice 2019 Tradesman and no FOB/Keys for it sitting in my driveway. HELP! LOL Bob
1,002
350
I used a third party key company to get a second one cut and programmed but I had my original key. More than likely the dealer will need the truck to get one made
bob1340
79
19
That is what I'm seeing. I'll have to get it towed to dealer and spend big $$$$! If the truck was over 5 years old a automotive locksmith could do it.
JeepJeep
Hi There ! My spare fob accidentially got swept off the counter into our recycle bin.... which went out to the recycle truck, before I realized it was "really missing"
The dealer can cut a new key via the vin number. I believe an authorized third part locksmith will also be able to cut the key from the vin. The key only opens the doors. The fob can also be programmed by either the dealer or a third party authorized locksmith. I believe Dodge uses an one time, limited duration ..24 hr, access code to program the fob.
I bought an oem fob on ebay (not programmed) for 75 bucks - brought it to the dealer, and complained it only worked sporadically. The service writer tried it, checked the battery, then threw it in the trash, and gave me a new one, programmed it in 15 min. - no charge.
If your vehicle has the u-connect radio/ head unit - I believe they can remotely activate a service to give you an emergency start, or even allow your smart phone to unlock and start the vehicle.... but I never really investigated those options.
Best of luck! Glad technology keeps making everything "better" : )
Also might give any bill to the work trucks insurance.....
954
492
What jeepJeep said, the dealer can fo it from the Vin number
bob1340
79
19
You lost a spare. I have zero.
bob1340
79
19
Update
I did find a mobile Locksmith who could do the job in the driveway. Pretty complicated process. He wired in a harness under my dash and then plugged that into a OBD2 harness going to a reader. This gave him the ability to get a PIN and program 2 FOB's. He then had to do similar stuff to get the code to cut keys. Took about 1/2 hour-45 minutes. Not cheap, but cheaper than getting it towed to the dealer.
