Fuel leak
Yostyy91
2015 eco diesel it is leaking fuel down the Back of the block down onto bell housing then onto the front driveshaft checked all injectors none are leaking but there looks like there is fuel laying under fuel rail on driver side
717
You will be jointing the flamed Ecodiesels if you continue to drive the truck.
717
Yostyy91
I understand that fuel and hot parts don’t mix and will catch fire I was asking if anyone knew what the issue could be cause I can’t find where it is leaking from I think it may be the return line back by the turbo
717
1st get rid of the sound foam, Maybe that will help in locating the leak, The lift and feed lines travel on driver side TOP of engine to distribution/transition block along driver side rail down the back to tank.Removed Sound insul 3.0 ecodiesel.jpg
Afrenock
Ever figure this out? Just replaced the coolant line under the manifold, buttoned everything up and now I have no start and fuel down the bellhousing. I had cracked all the lines to bleed, but everything is tight now. Seems to be when high pressure pump comes on during cranking, not just with key on for lift pump.
DCTruck
Did you ever figure your problem out I am having the exact issue right this very second anything will help thanks!
