GDE Transmission Tune
Godzuki
There are only 7 reviews about the Ecodiesel transmission tune on the GDE website. I'm wondering if anyone on this forum has this mod can attest to the good/bad of this tune. In terms of real-world performance, how much more does the GDE transmission tune offer over the standard GDE Hot Tune?
522
135
I never looked into it. You should call GDE, they are nice guys. I email them with questions and they answer right away. If I towed anything more than an occasional jet ski or utility trailer I would look into it.
Green Diesel
115
103
Most folks don't write a review, but we have over 700 trucks successfully running our trans tune. It works very well on this application and can be customized if needed.
Firstsage
59
23
Hi @Green Diesel! First off I did end up going with the PPEI tune mostly because I could add the switch to change the tune and the release of the hand-held option. That said, I have been looking at your trans flash and wanted to know your opinion on using your trans tune, either on a stock engine, or when used with a 3rd party flash.
I completely understand that you can not test every scenario/combination. Just looking for your professional opinion on how you feel the product would work with these.
Thanks!
Jon
Firstsage
59
23
I wrote into GDE product support email asking the above question. Here is the response:
Our trans tune will work fine with PPEI engine tune. PPEI does not output an accurate torque signal to trans and that can have some effect, but it should not be a big issue.
I'll more than likely be ordering a trans tune within the next month.
