GDE tune installed with EGT removed on my 2015 ecodiesel 3.0L
Stormline
Joined
Feb 16, 2019
Messages
Now with the EGT removed will this protect me from the engine going on fire!??
2.0
I have notice that my ADD Blue indicator has steadily gone from 2/3 full down to closer to empty after 10K miles, hence it’s been using it up, what happens when it get to Empty ? I presume noting with my tune ? Correct ??
thanks for your help fellows
If you got the new gde tune you will still need def fluid.
1.0
2.0
No! With or without tune, if you run out of DEF it will run about 30 to 40 miles after the "EMPTY" notice and will stop cold. To repeat; Ecodiesel rams will not run without DEF.
