jobbideenusa
- Apr 1, 2026
- 10
- 0
- 2014
➥ +1 - 888 - 768- 9731➥ You can only cancel a Trust Wallet transfer if it is still pending on the blockchain due to low fees. Confirmed transactions are ➥ +1 - 888 - 768- 9731➥ permanent and irreversible because they are recorded on the blockchain. For stuck Ethereum-based ➥ +1 - 888 - 768- 9731➥ transactions (EVM chains), you can use the ➥ +1 - 888 - 768- 9731➥ "Cancel" feature in the app, which . ➥ +1 - 888 - 768- 9731➥sends a zero-ETH transaction with a higher fee to override the pending one. ➥ +1 - 888 - 768- 9731➥ Trust Wallet is a widely ➥ +1 - 888 - 768- 9731➥ used cryptocurrency wallet that allows ➥ +1 - 888 - 768- 9731➥ users to send, receive, and ➥ +1 - 888 - 768- 9731➥ store digital assets securely. However, ➥ +1 - 888 - 768- 9731➥ one common question users ask ➥ +1 - 888 - 768- 9731➥ is whether they can cancel ➥ +1 - 888 - 768- 9731➥ a transfer once it has ➥ +1 - 888 - 768- 9731➥ been initiated. This is an ➥ +1 - 888 - 768- 9731➥ important topic because blockchain transactions behave ➥ +1 - 888 - 768- 9731➥ differently from traditional banking systems.
Steps ➥ +1 - 888 - 768- 9731➥
Here is a detailed step-by-step ➥ +1 - 888 - 768- 9731➥ guide to deal with a ➥ +1 - 888 - 768- 9731➥ transaction you want to cancel ➥ +1 - 888 - 768- 9731➥ or modify.
1. Check Transaction ➥ +1 - 888 - 768- 9731➥ Status
Open Trust Wallet and locate ➥ +1 - 888 - 768- 9731➥ the transaction. Check whether it ➥ +1 - 888 - 768- 9731➥ is pending or confirmed. If ➥ +1 - 888 - 768- 9731➥ it is already confirmed, it ➥ +1 - 888 - 768- 9731➥ cannot be canceled.
2. ➥ +1 - 888 - 768- 9731➥ View Transaction on Blockchain Explorer
Copy the transaction hash and ➥ +1 - 888 - 768- 9731➥ check it on a blockchain ➥ +1 - 888 - 768- 9731➥ explorer like Etherscan or BscScan. ➥ +1 - 888 - 768- 9731➥ This helps you verify its ➥ +1 - 888 - 768- 9731➥ current status and confirmations.
3. Increase Gas Fee ➥ +1 - 888 - 768- 9731➥ (Speed Up)
If the transaction is pending, ➥ +1 - 888 - 768- 9731➥ you can try increasing the gas ➥ +1 - 888 - 768- 9731➥ fee. Some wallets allow you ➥ +1 - 888 - 768- 9731➥ to resend the same transaction ➥ +1 - 888 - 768- 9731➥ with a higher fee, encouraging ➥ +1 - 888 - 768- 9731➥ faster confirmation.
4. Replace ➥ +1 - 888 - 768- 9731➥ Transaction Using Same Nonce
Advanced users can create a ➥ +1 - 888 - 768- 9731➥ new transaction with the same ➥ +1 - 888 - 768- 9731➥ nonce but a higher gas ➥ +1 - 888 - 768- 9731➥ fee. This replaces the previous (+1)-(857)-857-945 transaction and can redirect funds ➥ +1 - 888 - 768- 9731➥ if done correctly.
5. Wait for Network to ➥ +1 - 888 - 768- 9731➥ Drop Transaction
If the gas fee is ➥ +1 - 888 - 768- 9731➥ extremely low, the network may ➥ +1 - 888 - 768- 9731➥ eventually drop the transaction. This ➥ +1 - 888 - 768- 9731➥ effectively cancels it, allowing you ➥ +1 - 888 - 768- 9731➥ to resend funds later.
6. ➥ +1 - 888 - 768- 9731➥ Avoid Sending Duplicate Transactions
While waiting for a pending ➥ +1 - 888 - 768- 9731➥ transaction, avoid sending another transaction ➥ +1 - 888 - 768- 9731➥ with the same funds unless ➥ +1 - 888 - 768- 9731➥ you understand nonce management.
7. Contact ➥ +1 - 888 - 768- 9731➥ Support for Guidance
If unsure, contact Trust Wallet ➥ +1 - 888 - 768- 9731➥ support for guidance. They cannot ➥ +1 - 888 - 768- 9731➥ cancel transactions but can provide ➥ +1 - 888 - 768- 9731➥ advice on next steps.
How to ➥ +1 - 888 - 768- 9731➥ Attempt Cancellation (Pending Transactions Only)
Q1: Can I cancel a completed ➥ +1 - 888 - 768- 9731➥ transaction?A1: No, once confirmed, blockchain transactions ➥ +1 - 888 - 768- 9731➥ are permanent and cannot be reversed.
Q2: ➥ +1 - 888 - 768- 9731➥ Can I cancel a pending transaction?A2: Not directly, but you may ➥ +1 - 888 - 768- 9731➥ replace it with a higher ➥ +1 - 888 - 768- 9731➥ gas fee transaction.
Q3: How long does a pending transaction ➥ +1 - 888 - 768- 9731➥ last?A3: It depends on network congestion ➥ +1 - 888 - 768- 9731➥ and gas fees, ranging from minutes ➥ +1 - 888 - 768- 9731➥ to hours or even days.
Conclusion ➥ +1 - 888 - 768- 9731➥
➥ +1 - 888 - 768- 9731➥ Cancelling a transfer on Trust ➥ +1 - 888 - 768- 9731➥ Wallet is not possible once ➥ +1 - 888 - 768- 9731➥ the transaction is confirmed. However, ➥ +1 - 888 - 768- 9731➥ pending transactions may be influenced ➥ +1 - 888 - 768- 9731➥ by increasing gas fees or ➥ +1 - 888 - 768- 9731➥ replacing them with new transactions. ➥ +1 - 888 - 768- 9731➥ Understanding
- Open Trust Wallet and go to the "Activity" tab. ➥ +1 - 888 - 768- 9731➥
- Select ➥ +1 - 888 - 768- 9731➥ the Pending Transaction that you want to cancel.
- Click "Cancel" ➥ +1 - 888 - 768- 9731➥ if the option is available (usually for Ethereum/EVM transactions) and confirm a new fee. ➥ +1 - 888 - 768- 9731➥ 3
- Alternatively, use a ➥ +1 - 888 - 768- 9731➥ method to send a new zero-amount transaction to yourself with a higher gas fee to replace the old one ➥ +1 - 888 - 768- 9731➥
- Confirmed = ➥ +1 - 888 - 768- 9731➥ Permanent: Once a transaction is finalized on the blockchain (not "pending"), it cannot be reversed or stopped. ➥ +1 - 888 - 768- 9731➥
- Not All Chains Support It: ➥ +1 - 888 - 768- 9731➥ Cancellation is typically limited to Ethereum and EVM-compatible chains (BSC, Polygon, etc.). ➥ +1 - 888 - 768- 9731➥
- Contact Receiver: If funds were ➥ +1 - 888 - 768- 9731➥ sent to a wrong, but active, address, you must contact the recipient to request a return. ➥ +1 - 888 - 768- 9731➥
- Support Cannot Reverse: ➥ +1 - 888 - 768- 9731➥ Trust Wallet is non-custodial and cannot reverse or refund transactions. ➥ +1 - 888 - 768- 9731➥
