Howdy
WillieT
Is the Coolant feed tube covered, as part of the turbo charge system? I've read on a tread here that it is, but also that it is not. Which is correct? I do have a copy of the AEM settlement parts list. FYI: I have a 2018 Ram Laramie 4x4
Ive also had the EGR replaced last year in March/April time frame.
Any feed back would be great
717
No on 2018, for AEM. The 100K/5yr, All is on the dealer pull and input. :(
Your 2018 should cover it 36k/3yr its not cover by the 100K/5yr DSL engine warranty.
Cylinder block and all internal parts; cylinder head assemblies; core plugs; fuel injection pump and injectors; intake and exhaust manifolds; oil pan; oil pump; timing gear drive belts and/or chains and cover; turbocharger housing and internal parts; valve covers; water pump and housing; seals and gaskets for listed components; glow plugs and all sensors
