Howling at 70mphs
Mpittmanfl
Ok. I’ve been trying to isolate a “howling” noise at around 70mph. It sounds like when a mechanical fan kicks on, but while driving it is very hard to isolate if it’s from the front, left, right, rear, I just can’t tell. I’ve checked wheel bearings, brakes, diff, etc. anyone had this sound before?
1,063
364
More than likely the rear pinion bearing. Mine does it primarily when I’m coasting and gets louder at high speeds and quieter as I slow down. Drove me nuts wondering but 70k and it’s still holding on lol
Mpittmanfl
Thank you, thats been on my list as well. It just started out of the blue a few weeks ago! Drives me NUTS!!
GuyNeco3
I had the same problem a mechanic told me it was the turbo the sound for me was after 60 going up hill and would quiet after 80?( Sometimes)This happened after I did the total delete kit.
Mpittmanfl
I did my delete 2 years ago and this is new. I’m going to verify that it’s not the axle seal/bearings and then move to pinion.. fun times to be had for sure!
GuyNeco3
Thanks I’ll let you know if it fixed my problem after I tested out my truck this weekend? Good luck with your investigation.
Mpittmanfl
I might have read your response wrong. Did he say your turbo was going bad?
GuyNeco3
Yes that is what I was told. I’m having a new one put in the truck it has 86k miles on it now I get it back Friday?
Mpittmanfl
Let me know. I have to get some free time and someone to drive me at highway speeds so I can listen from the back and see what I hear.
