Major coolant leak
Dragon
I ran low on coolant a few weeks back hauling a trailer it was a long haul and I topped it off and made the rest of the trip home well this past weekend I started running low on coolant and was topping off pretty regular trying to find to point it was leaking from now i have coolant pouring from around the trans when I add coolant and all coolant is out within a few miles what could the source be?
283
welcome 2 the group its the turbo cooling line its about 200 d0llars and around a thousand 2 install
283
the only way 2 see the line is pull the intake off if it is running down over the Trans its leaking very common ptoblem
Dragon
Brought it to the shop it was the turbo cooling line and a slight leak in the radiator both replaced but my coolant is sitting low after topping off once with a whole gallon it was full when I picked it up I made sure to check it’s not overheating but it isn’t staying up to the full line I’m wondering if they didn’t pressure test it before they released it back to me
NC-RAM
61
21
What is the function of the 3 way valve for coolant going to the transmission?
got code the other day, so I purchased one to install.
Assuming the transmission needs coolant to keep temperatures down, so here is my question.
Why not delete the 3 way valve, and just put in a 3 way tee. That way the transmission can get coolant all the time? Would that be a problem? My transmission temps never has gotten any hotter than the radiator temp.
just wondering if someone could explain this for me.
thank you,
NC-RAM
61
21
EGR cooler? Any word on this from the dealer yet?
what if you truck is out of warranty?
klinder
I believe the EGR cooler failure is a recall Item on the Ram 1500 eco diesel. So even if you are out of warranty it should be replaced by dodge at no cost to you. Call them CFC canada of the dodge affiliate
