Nitrogen Air ride
madman
hello my fellow ram owners, I had a problem with the right rear suspension dropping, a lot of people on here told me I probably had a pinhole leak in the bag as it only done it in the cold weather, well last Saturday I replaced both rear bags ( done it my self ) now I need to get the system filled back up with nitrogen, im in Utah, does anybody know who does this other than the dealership? or what kind of charge I can expect from the dealership? has anyone had this done? when I talked to my dealership the Service writer was pretty ignorant, and seemed like they didn't really want to help because I changed the bags myself! thanks for any help
1,002
350
Could probably talk to a local hvac company, every van has a tank on it and can probably do it! I was under the impression they were compressed air not nitrogen.
1,002
350
Check this video out for location and fitting used. Not sure sure pressure setting though.
madman
update....
I took the truck to the dealer, after lots of arguments they finally checked the system for leaks ( so they said ) and filled the nitrogen. 352.00 was what they charged me, but I still don't feel like the truck is holding its height, after sitting the night it seems it drops about an inch, wondering what to look at next? thanks
Abarbe
Hi Madman,
Make sure your truck is parked on a perfectly level area as the truck will automatically raise and lower to make the truck level to compensate for any uneven ground it is parked on. If you park on a really level spot and you still find the truck has lowered, then you still have a leak.
