Thekidd1965
- Jun 13, 2022
- 3
- 0
- 2015
Hi, I am looking for some help please. My ram 1500 2015 ecodiesel through a p24c2 code. What does this mean? Any advice appreciated...
Thank you for your reply, the boots to the exhaust are intaked, I took abort and cleaned the dpf injector, unfortunately I broke the clamp for the injector. I will get and replace it tomorrow. If that works, I will find out tomorrow. If not the dpf has 6 sensors. Is their a way to see which sensor? To replace all 6 would be expensive, better off doing a delete. Thanks you for your helpCheck your three exhaust flange bolts near the passenger side front floor board to see if they are in tact, if those are good you most likely have a sensor going bad in the exhaust. Keep in mind that these sensors also impact your trucks ability to regen, so it won’t regenerate until fixed and can throw you into limp mode
