Throttle hesitation
cajerney
What is the cause of the throttle hesitation from a stop? My 2015 eco diesel has had it forever. Since the exhaust recall was done the hesitation is worse. I have not done any changes to the original software.
-STIGLITZ-
145
45
It’s just a product of the AEM. If I read correctly, it’s a 2.8 second delay. I’m sure one of the more knowledgeable folks will chime in.
cajerney
Exactly correct. It is a bit unnerving pulling into traffic not knowing i.d the vehicle will go.
380
132
I have read on other forums as well as this one that FCA programmed up to a 4 second delay of the turbo on cold run to "protect the engine" damn near killed me in traffic, there is a 2.8 second delay in turbo on warm run, not sure why. My question is why have a variable vane turbo, which by design can be more responsive, to only program delay into the boost to emulate a static vane turbo? Since all but STK tuners have been shut down the quick easy fix for the throttle (turbo) delay is the fly by wire booster.
Good Luck.
380
132
I have no dangerous hesitation with the AEM.
My wife's Jeep GC eco had delay but not as bad as my RAM. My truck would only make enough power to slow roll, when light changed I was still in intersection. When delay stopped the engine hit redline, wheels spinning, let off throttle to control, back into the throttle to the same delay. My wife told me after driving my truck she would have driven straight to the dealer and traded. We received the notification today of an improved AEM program to correct the delay. Will not be partaking of the new program, would over write our fixes.
-STIGLITZ-
145
45
Dude, that delay was no joke. I once pulled out onto a busy intersection and saw my life flash before my eyes lol.
Operations
I hate the turbo lag my truck has. I plan on doing an EGR, DPF & SCR delete. Also an H&S compound turbo with the pedal commander. I’m looking at around 350hp and much better take off
-STIGLITZ-
145
45
Good luck with the delete man. I wouldn’t do it again, if someone paid me. Once it’s done, however, it’s a completely different truck!
Operations
All the research I’ve done looks like it’ll be a task. The end result seems well worth it though.
-STIGLITZ-
145
45
Absolutely it is. I’d recommend leaving the rear EGR riser tube in place. I paid quite a bit to have broken bolts extracted when I could’ve just blocked the damn thing off. Reach out with any questions man.
Operations
Thanks
