Torque pro app???
Dmckeen03
I'm running torque pro app to see all the information like a edge CTS does anyone know a site to find all the PIDS ?? Looking for one that tells what gear transmission is In 2206
cds13ca
216
76
not sure about the gear selector, but I have the PID's for the regen ON / OFF if you want. Good to know when the truck is in REGEN mode behind the scenes.
PID 018b
Long Name: DPF REGEN MODE
Short Name: RegenMode
Min Value 0.0
Max Value 1.0
Scale x1
Unit Type: MODE
Equation {B:0}
Then I just set it as an ON/OFF switch
cds13ca
216
76
If you also want the PID for the DPF Temp reading, this is a good one cause here's where you can see it jump from an average of 400 up to 1300 F when it's in regen... then settle back down to 400-500 F when regen is OFF. The whole cycle is about 12-15 min and happens without most people even knowing it's happening (other than noticing that your MPG is a lot lower... during regens). But being able to see a regen is occurring explains why your mpg is lower...
PID: 013c
Long N: DPF TEMPERATURE (custome)
Short N: DPF TEMP
Min Value: 0.0
Max value: 725.0
Scale F x1
Unit Type: oC
Equation: ((A*256)+B)/10
Dmckeen03
PID 018b
Min Value 0.0
Max Value 1.0
Scale x1
Unit Type: MODE
Equation {B:0}
Yes I have that set up now I did it shortly after posting this picture would like to know if theres a gear one like the edge programmer 22082209
cds13ca
216
76
not sure, haven't seen that one. YOu can see gears up on the EVIC display though, just his the minus gear button, then move it up to 8, and beside it is what gear you're in.
Dmckeen03
Yea I know that one just always have to do it to see an if i had the pid for it it always be in the view
cds13ca
216
76
at the bottom right, beside the D, the # on the left is the current gear 1, on the right is the max gear 8 you want it to stop shifting at.
Dmckeen03
Yea I know that already just a pain an shitty thing I hate about it .. you can force it down gear but not up just set the max gear
Mac
43
So I have the GDE tune on the transmission that forces the gear into the gear selected on the read out display. So when I hit the paddle it will force it into the gear that I select. Very nice for dirt and snowy roads. However, I’ve lost the ability to use my paddles to see the gear I’m in when driving around in “automatic” mode. I’m trying to find the PID for the transmission on this thing. I found the PID for ram 2530 and 3500, but not 1500. It’s got to be somewhere…?
