Towing
Tex0326
Has anyone have any problems pulling 8,000 lb machines with there ecodiesel 4x4
Promo714
I have a 2018 Limited 4x4 with 6'+ bed and I pull a 7500# travel trailer with no problem at all. I can run 70 mph for hours; plus I've never had a problem with oil overheating. I would not hesitate to go up to 8000 based on my experience, but I'm also running both an engine and trans tune and that reportedly helps. Have never towed without the tunes.
887
363
I have a 2015
There is basically no difference from 2015 to 2018. What is your axle ratio? do you have air suspension? load equalizing hitch?will you be pulling a lot of passes? there are a lot of variables...
Tex0326
No air suspension I'm not sure on the gear ratio it's a quad cab truck
Tex0326
I know my transmission has been run at 198 degrees all the time within 15 miles when warmed up and I dont know if that's normal and that's only at 75mph
Will_CathVT
77
25
I have a 16 and my transmission will average 190 and I live in VT. I don't use the highway often and don't exceed 70mph, most of my driving is around 50-55mph on secondary roads. My transmission temp will escalate when towing my 6000 pound travel trailer or if I'm pulling big hills. The temperature never exceeded 210.
