Turn signal issues
ChiefK
I got an error notification regarding a front driver side turn signal out and back passenger tail light out. (None of which are actually out). When I turn left the indicator on the control panel flashes fast, the outside indicators flash at normal speed except for the mirror turn signal, it flashes at the same rate as the light in the instrument panel. Any ideas? I checked all fuses and lights all seem to be fine.
NewKid
I am trying to see if anyone else has run into the same problem as me. I have a 2016 ram 1500 ecodiesel. The message came up that the rear passenger turn signal is out. I replaced both rear turn signals and now I have a message for both sides and driving lights. Any help is greatly appreciated.
ChiefK
LED lights?
ChiefK
The ones that the error notifications are telling u are out
Turns out one very small LED is out and throwing everything off. Replacement is pricy, gonna wait awhile to replace that headlight.
Handyguy9
I am struggling with a 2017 eco diesel which tells me the drivers side signal light is out. The light was just replaced due to an accident and all the led bulbs are working in all three signals (front, rear and mirror). Does the computer need to be reset to recognise the front replaced light? Mine is also flashing quickly to indicate a light is out but none are and they all work. It is just annoying to have the warning come up on the dash and the indicator to blink quickly. Thanks for any help.
1,002
350
I had an issue when I added led headlights and fog lights with my truck telling me my reverse bulbs (led)were out when they had been led since I bought the truck. I added the error message cancellers to the headlamps and haven’t had another issue. These trucks are very sensitive and don’t like aftermarket bulbs other than what it came with factory. In alfaobd software you can change the settings to accept led bulbs front and rear, but can still get the messages. If it was in an accident, I’d assume a wire got kicked and isn’t communicating properly
