2014 Dodge Ram 1500 ecodiesel
sosuch
We purchased it in March with 77000 miles. Bought extended warranty. Tried to Drive it to CT in June. Broke down in VA. Dodge dealer replaced hose. Did not stop coolant leak. Took it to local shop where purchased. They replaced radiator cap and coolant reservoir. Did not stop leak. CEL came on took it to dealer. They said too much pressure. Now say it is EGR system. Parts alone cost $2200!!! Not covered by warranty. Need advice.
283
Welcome to the group it is covered don't let them bull shit you it is covered under the extended warrenty
cds13ca
216
76
are you talking about the egr cooler? ya, that is $$$$$$... I'm not sure, you have a 2014, I doubt you're still covered under warranty? If the egr cooler is the issue, and you're not covered, you have the option to buy an EGR delete kit (stage 2) and drop out the egr cooler, install the bypass, and of course, you'll need a tune to shut off the egr electronically too.
Tough decision, this option is cheaper than a shitty egr cooler that is known to leak after a few years anyway, and you certainly don't want to be replacing that over and over everytime it springs a leak...
Question - are you seeing puddles of coolant? or do you just have coolant disappearing with no signs of a leak or puddles on the driveway? If it's the egr cooler, you won't see any puddles, just notice it disappearing.
We live in AR with no emissions check does it still apply.
Yes it applies to all 2014-2016's after completing the AEM.
Consent Decree Appendix E
Extended Emission Warranty
Subject to standard limitations that must be identified to Eligible Owners and Eligible
Lessees, which may set forth exclusions like accident, abuse, neglect, or installation of noncertified parts, and applicable existing warranty provisions that will remain in effect, the
below.
• Catalysts
o DEF Injector
o DEF Injector Controller
o DEF Storage Tank
o DEF Delivery Lines
Cherokee only)
• Parts of the Fuel System
o Fuel Injectors
o Fuel Rail
o High Pressure Fuel Line
o EGR Cooler Tubes
o EGR Cooler
o EGR Valve
o EGR Temperature Sensor
o EGR Cooler bypass actuator
o Oxygen Sensors
o NOx Sensors
o Fuel/Water Separator Sensor
o Particulate Matter Sensor
o Mass Airflow Sensor
o Boost Pressure Sensor
o Crankcase Pressure Sensor
APPENDIX E TO CONSENT DECREE
MDL No. 2777 EMC
Case 3:17-md-02777-EMC Document 484-1 Filed 01/10/19 Page 207 of 224
o Throttle Valve
o Exhaust Temperature Sensor
• Throttle Valve
• Cylinder Head Assembly, Including Valves, Springs, Valve Spring Keepers, Valve Seats,
Cam Bearing Caps, and Manifold Studs (Camshaft and other components of the assembly
are not covered)
Additionally, the Extended Warranty shall cover the cost of any OBD Diagnostic Scan
for malfunctions that trigger the OBD Malfunction Indicator Light (MIL), regardless of whether
the malfunction is attributable to a part that is covered under the Extended Warranty
Old man
26
Ram is covering intake manifold swirl valve do to soot build up making it inoperable covered under emissions warranty new manifold on order
