2014 oil pressure????
wlb862
So I've got a 2014 ed and I can't figure out for the life of me what it's correct oil pressure is supposed to be... It was usually right around 30 but now it varies between 24 to 50.... Is this normal? I got my oil changed and it's still doing it.... I was told that my oil pan gaskets need to get changed. Could this be the problem? Or is it even a problem? Please someone help me.
1,246
338
The oil pressure displayed on your evic is just load and temp calculated. There's not an honest reading or sensor. I've not heard of a pan leaking but I'd check torque myself if there's a loose spot on what's likely a permadry gasket before committing to a reseal.
wlb862
The pan is leaking, so that has to get done... I just didn't know if this was what was causing the flux
1,246
338
It's a fake generated reading so disregard
