2016 ecodiesel rolls over but won t start
Rgor06
I have a 2016 eco diesel drove home last nite park turned off ignition and this morning it rolls over but will not start any idea what could be wrong
Rgor06
How would i go about checking the lift pump
915
333
Turn the key to run, but not all the way to engage the starter and listen carefully near the bed to hear the pump turn on, the pump should run for 5-10 seconds at a whine sound.
Rgor06
I can hear the pump start and run it stop after about 20 seconds
915
333
Hm, it may be losing prime. I don’t think mine runs that long. You can try the same procedure 3 times then attempt to start. Have you serviced the fuel filter? Are any codes present?
694
It runs 10-20 seconds (Feed in tank Pump) , Plus you need to allow the internal Clock to re-set before it will run ... again ... W/O engine running.
Also it needs to make more then 45/50PSI to overcome the COV in the CP4 to open the FCA feed circuit, plus you need to make more then 1800PSI Cranking rail Pressure for the Pressure sensor to send signal to ECM/PCM to Fire the hot hole. This is 1 of many reasons why it won't start.
